Rear Disc Pad Change
I need to change out the rear brake pads on my 02 protege 5
I can't seem to get the rear calipers to retract allowing the new pads to be installed, I'm using the old C-Clamp method. Is there some trick here? Please help anybody. |
RE: Rear Disc Pad Change
THERE IS A SCREW THAT NEEDS TO BE BACKED OUT IN ORDER TO GET THE PISTON BACK
theres an allen screw on the back side of the caliper
Hopefully they figured that out back in July. If not then is way to late to help on this question.
this makes me think you should have someone that knows your vehicle fix your vehicle. let me know when your out driving...so im not anywhere around you....ok! |
