Part of my plastic dipstick is floating around in my oil pan. Dangerous?
Old 01-26-2013, 10:51 PM
9Shenandoah's Avatar
Default Part of my plastic dipstick is floating around in my oil pan. Dangerous?
I broke my plastic dipstick on my 1999 ( 2000) Mazda Protege 5 speed ZM engine while I was wrestling around changing the timing belt. I left it that way fora few months.
The other day, I tried to retreive the broken dipstick part by sliding a metal dipstick down the tube in an effort to snag it.
I ended up pushing it into the oil pan. I am assuming theres about a 19" to one foot long section of yellow plastic floating around in my pan.
Common sense tells me its nothing to worry about, after its plastic and its not going up the oil pump tube because theres a screen on it.
But 20 years ago, I left a small metal clamp in my valve cover and belive it or not it got lodged in a perfect position to score the camshaft and break it!
So I am thinking , with my luck it'll get sucked up into a connecting rod and jam a piston, though the plastic is not that strong.
Any suggestions?
Old 01-27-2013, 06:13 AM
tanprotege's Avatar
i would expect no problems because of Moore's law: the harder harder material will scratch the softer one. I also expect it to be oil resistant. after all it is a dipstick!
The only potential issue I can think of: if the dip stick gets ground up then there are small floaties in the oil that potentially get past the screen.
There is your excuse if you want to take the pan off. But with your habit of leaving stuff in an open engine.... I hope yo are not a surgeon!
Old 01-28-2013, 05:19 AM
Default Actually I am pretty carefull
and thats why I want to atke it out. I once tore apart a newly rebuilt 4 speedbecause a brass washer got into it, took me two weeks.
Don't worry its coming off..
Old 01-28-2013, 07:40 AM
Thumbs up
That's what i would do. Now you will sleep better!
Old 01-30-2013, 05:19 AM
Default Its 3 am on the west Coast and I'm at it
Remebering when I was 20 years younger and I would pull an nighters rebuilding engines and race cars and a perfectionist. Now i am married with family and job and its a wrestling match just to keep a fleet of five used cars running
Old 08-18-2018, 08:36 PM
Rob Rundquist's Avatar
the dipstick handle just broke off of my cx7..ugh.
It comes thru the middle of the engine, anyone have thoughts on how to get it out?
2010 2.5L
Old 08-20-2018, 09:38 AM
Saudade's Avatar
2010 2.5L
Welcome! You might try asking in the CX-7 forum. The would know more about it.
chizzeledman81
12-14-2023 10:44 AM
Nick Heap
12-04-2013 05:10 AM
BogusSVO
02-01-2010 06:28 PM
Tovic74
03-11-2007 08:34 AM
tsb2600
10-13-2005 09:35 PM
Quick Reply: Part of my plastic dipstick is floating around in my oil pan. Dangerous?
