P1195 97 protege
P1195 is an EGR boost sensor code. Follow the instructions in the link below. It is a common problem. You may end up having to replace it. If so, just go to the junkyard and get both the sensor and the attached solenoid. THey won't it you for much. But you will need to do this procedure even if you replace it.
https://www.mazdaforum.com/m_64575/tm.htm
1997, 97, barometric, biometric, code, fixed, mazda, mazdap1195, p1195, p1195protege, parametric, pressure, protege, protoge, sensor
