P0106 Code.... 2003 P5
Old Mar 5, 2026 | 09:48 AM
Because you either keep reset the DTC which is active and the ECU will turn off the dash check engine light. The DC will remain in the permanent file are of your ECU and cycle through until the cause of the DTC was corrected. After 1-several complete engine cycles if the problem was not correct the check engine light is then back on. This all means that you are not finding the cause and are guessing at what might be the faulty part. By doing that type of hit and miss more times than not causes other unresolved issues making the original cause more challenging to find.
It may help to find all the permeant DTC as well go look at the I/M monitors.
Your posting is not uncommon for DIY attempting to diagnose problem related to the ECU operation and thinking that that one DTC and th related information to that DTC must be the problem. Most all DTC have several causes and possible parts that could have caused the DTC that each part must be first checked to verify they are faulty or failed. If none are found bad, then the cause must be diagnosed by other causes that could have shown that single or multiple DTCs. One faster method is if the scanner has and the operator has trained experience can view the live data feed or what I prefer is using a oscilloscope and look at real time operations which can faster lead to causes of the problem and the DTC being generated.
Old Mar 5, 2026 | 09:57 AM
Old Mar 26, 2026 | 02:29 PM
Saudade's Avatar
So to close this out (again, for good), I changed the EGR Solenoid the following day (from my previous post) and replaced the vac line (connects EGR solenoid to MAP). It's been a few weeks and about 500 miles of mixed driving. No codes, all monitors complete.
Old Mar 26, 2026 | 04:10 PM
Adyimbo
Jul 28, 2021 07:37 PM
Taz 454
Jun 22, 2021 06:23 AM
Dylan Safruik
Nov 28, 2017 02:19 PM
erik2282
May 6, 2015 11:10 AM
zr1mark
Jan 27, 2010 01:16 PM
