Overheating while driving not idle and no heat
Old Jun 2, 2019 | 07:44 PM
Mp3knowhow's Avatar
Default Overheating while driving not idle and no heat
Okay so my car started to overheat when driving but doesn't when I'm idle and I have no heat. I changed out the radiator and the thermostat. I also flushed the heater core both from inlet to return and return to inlet. I'm full on fluid also. I noticed the return line on the heater core is cold while the inlet is hot that is why I flushed it but even after the flush it didn't change anything. I still have no heat and overheats when I drive. Any suggestions and advice would be really appreciated
Old Jun 5, 2019 | 09:54 PM
tinyestmantis's Avatar
Smile
The other day when i was going for a cruise. my thermostat shot to H and i noticed my fan was intermittent and so i did some poking around and it turned out the plug circled in the picture in the attachment was pinched or something so i disassembled the switch and temporarily secured the wire to its post inside the female end of the plug, and when i got home i redid the plug and it worked great afterwards, my car was a 1990 protege but it should be a bit similar in concept if that's what the issue turns out to be. hope this helps man. best of luck to ya!
CareToLynn
Apr 9, 2018 10:48 AM
technoobie
Dec 1, 2010 12:53 PM
jukesandz
Mar 8, 2009 05:23 PM
cmatamoros
Oct 22, 2007 05:23 PM
