No ignition spark
I have a Mazda Protege of 1999.
The motor does notrun because there is no ignition spark, the timing belt is OK. Somebody can help me |
RE: No ignition spark
Check cap, rotor, then distributor. Back from there you want to check engine management CPU, Is it giving a check engine light???
No longer there is problem. The gasoline pump was in short circuit and burned the fuse that feeds the injectors and the ignition system;).
Replace the fuel pressure regulator with the pump or it will likely fry the new pump soon.
Thankyou Hixx,I´ll check it up.;)
