Mazda protege 2002 es 145,000 km 2.0l manual
Are there any pictures or schematic diagrams from shop manuals in which I can locate the clutch slave cylinder?
I would like to know if this vehicle has a separate master cylinder or uses the brake master cylinder? What DOT (number) brake fluid is required? Thank you all in advance |
the clutch master cylinder at the firewall. just follow the little hose that comes out from the fluid reservoir of the brake master cylinder. the clutch slave is at the transmission, facing the front of the car. it actuates the clutch release fork. follow the fluid lines from the clutch master cylinder. it has a bleeder nut just like the ones found on the brakes.
