Mazda 1997 Protege
Old 10-19-2018, 08:07 PM
Tomcat22's Avatar
Default Mazda 1997 Protege
Hi I recently noticed that the idle on my 97 Mazda Protege was running low and the check engine light was on so I had it tested and it showed it was the idle air control valve so I replaced it and reset the computer by disconnecting the battery but right away the idle was still doing the same thing and the check engine light was back on and I had it tested again and it showed the same thing any suggestions the car has 171 thousand miles
Old 10-20-2018, 06:23 AM
What was the actual Fault code?
Old 12-26-2018, 12:56 PM
Tomcat22's Avatar
p0505
Old 12-28-2018, 06:28 AM
Clean the MAF & throttle body. Reset computer. Start the engine & spray brake clean or water around the intake manifold and intake pipe to check for leaks.
Old 08-30-2021, 09:36 PM
SteveO1976's Avatar
​​​​​​Erratic idle goes from 2200 - 1500 runs great replaced the IAC and the MAP sensor waiting for the TBS.
Any thoughts need help
notla
12-03-2012 03:55 PM
323F
02-18-2012 05:13 AM
mike2
03-18-2011 04:18 PM
whitebear93
09-26-2009 04:58 PM
jbkoenma
08-17-2008 09:04 PM
Quick Reply: Mazda 1997 Protege
