help car won't start
I have a 94 protege, and i just replaced both the master clutch cylinder and the bottom cylinder. Now it won't start it won't even turn over, and you can't hear the starter click. The lights work and everything. I recently got this car for 350 dollars in a tow yard auction. Its not in bad condition. My cousins told me its the clucth switch, batturys, or the distributer. I would really appricate the help. :D
check all of your grounding locations. you might have knocked a ground wire loose while you were working on it.
The clutch switch is a simple 2 wire make/break switch so you can just jump the 2 wires together to bypass it.
