Headlight retaining spring
i was rushing to replace a headlight bulb on my wifes 2002 Protege 5, the retaining spring came out, is there a easy way to reinstall it? other than taking the whole assembly out? I saw a small screw off to the side i think might mount it, any help is appreciated.
also i need to replace a brake light bulb, but i need to buy a deep socket, what size is it, 8 mm? |
Originally Posted by imtrouble
(Post 119680)
also i need to replace a brake light bulb, but i need to buy a deep socket, what size is it, 8 mm? undo the screw a little bit and put the spring back in place then tighten it down |
thanks, but now since it was apart the retaining spring is missing, can they be bought separately or do you have to buy the whole assembly? or find one at a auto wrecker?
