-   Mazda Protege (https://www.mazdaforum.com/forum/mazda-protege-23/)
-   -   Headlight Bulb Replacement? (https://www.mazdaforum.com/forum/mazda-protege-23/headlight-bulb-replacement-12974/)
fortysixxand2 Feb 25, 2008 07:56 PM
I have bought some sylvania head bulbs for my 2000 lx protege. Simple upgrade huh? Well after about 2 hours of frustratingly pulling at the wire harness i gave up. Anybody else had this problem? I know im doing it right (pushing the 2 side tabs and pulling out?) but the POS just won't come off. Thanks for any help in advance.[/align]
s0n1cm0nk3y Mar 1, 2008 12:59 AM
RE: Headlight Bulb Replacement?
what exactly are you having problems with.
the process its usually as follows:
remove plug
remove rubber gasket
push down and pull out pin
remove old bulb (dont touch bulb)
insert new bulb (dont touch bulb)
install gasket again
install plug again.
where is it that you are having trouble.
also bare with me, i am new to the mazda scene myself, but i installed my xenons on my 03 mazda dx.
wsoape281 Mar 1, 2008 06:54 PM
first, the clip, just on one end, pushes in and over before it pops out. second, there is a little adapter that goes in between the light and harness. this adapter must be kept. it is hard plastic and the mini bulb plugs into one end and the wiring harness plugs into the other. these are the two most common problems that people have in headlights.
and, yes, if you touch the headlamp itself, it will leave enough of your oils from your hands to heat up and explode inside the housing.
fortysixxand2 Mar 2, 2008 07:57 AM
Well the wire harness was apparently in there very tightly, like everything else seems to be on my protege? I did however get them out and replace and put some stuff on it so it'll be alot easier next time haha.
Anddddd Slyvania silverstars are amazing. Make a lot of people mad :).
wsoape281 Mar 2, 2008 01:11 PM
yeah, that's what i am using. they look like brights with the low-beams, huh?
fortysixxand2 Mar 2, 2008 09:04 PM
Hahaha yeah I love them, first person i drove behind at night got so pissed that theykept pumping the brakes and finally I put the highs on and they realized and pulled a U'ie for me to pass hahaha. Sorry can't help it I have superior lighting to yours =p.
Jonathan Robinson Dec 6, 2017 03:51 PM
So they are just tight?
So, I'm having the same problem with my 2003 protege 5, pain in the ass. They are just tight? 2hen I compress sides I don't really feel anything moving and I'm cranking the **** out of them...my hands hurt! Lol
Mb001267! Sep 29, 2023 11:03 AM
Hi,
Hope this helps. I have a youtube channel, where I have posted a video on how to replace your Headlight bulbs on a Mazda Protege (1998 to 2003). This works for some other mazda's from that year range. Would love if the Mazda Community would subscibe my channel. I plan to be posting more DIY videos with repairs and fixes on the Mazda. Thank you!
VictoriaFergusonn Nov 24, 2023 11:41 AM
