Head gasket replacement
I'm in the process of taking the head of I got most of the bolts I can see is there any other ones I don't know about and also u plan on going turbo is there a more durable gasket I can get and where thanks
You will want a gasket that lowers your compression so I think it will be a thicker gasket but I'm not 100% on if its thicker or smaller because if you keep the same compression as stock it will blow the motor the compression will be to high the turbo will balance the compression once its on with a lower compression gasket.
