front bumper
i have a 2002 protege, if i wanted to put a protege5 front bumper on it, what would i have to do?
RE: front bumper
the bumper is a direct fit. you may just need to add a couple of stock supports from the p5.
RE: front bumper
Do you know if P5 headlights fit Proteges of the same model year?
RE: front bumper
p5 headlights will fit, but there will be some modification for the high beams/low beams to work. the sedan has a dual element, single bulb set up on the housing where the p5 has a dual bulb, single element. that means that the wiring needs to be modified either with a harness or with an adaptor.
