Floor board soaked on front passenger side...
I just noticed that the floor board on the passenger side is soaked. My window seals fine and so does the windshield, as its rather new. I have no clue why its soaked as I cant detect anything leaking. I did find a plastic hose which attaches to a black cone shaped piece that I think goes to the blower motor was disconnected so I attached that with a small hose clamp. I sucked up most of the water with my wet/dry vac but its still wet so now I have a towel there.
We did have a huge snow storm here recently but it doesnt explain why only the passenger side front only got soaked. If anyone can help me figure this out I would greatly appreciate it because I am at a total lose :confused: |
could be simply snow melting over the seal.
could be you need a new cabin filter or the drainways around it are blocked. Worst case could be a heater matrix - but you will lose water coolant if thats the case and the water in the car footwell will be orange or green (depending on antifreeze used) Check cabin filter and drainage channels first |
| All times are GMT -5. The time now is 05:57 AM. |
