Correct auto transaxle fluid
Hi Mazda lovers! Hey I just got a 2003 Protege with an automatic trans and wanted to change all the fluids, filters etc and the only thing I can't seem to find is the type of atf to use in the transaxle. The factory manual says ATF MV which I assume is Mercon V but am not sure. I just bought some Mobil 1 syn that is Mercon V approved along with Dex etc. What is the correct fluid to use? Thanks! H |
RE: Correct auto transaxle fluid
Cmon you guys I need this answer today if possible please?
H |
Wow a new member gets no response. Thanks for the help.
did you pull the trans dipstick and read what that says?
Yes, and it says nothing in regards to fluid type. Thanks for replying I was starting to get a complex.
H |
it uses mercon, apparently it is roughly a ford product.
It is a Ford transaxle
