cigar lighter, and wiring questions
My cigar lighter socket does not work, and along with the power to adjust the side mirrors. I checked my fuses and none of them are blown. Any idea?:confused:
How did you check ? Visual only ?
First, a fuse can be blown but appear OK. You have to remove it and check it for continuity. Second, having made certain you're dealing with a good fuse, be sure it's bedded really well into the receptacle on the fuse block. Third, check whatever was the last thing you plugged into the lighter socket; it's not uncommon for them to cause short circuits in the socket. |
hes right check the fuse with more than just a glance
