cant go past half throttle
i have a '98 protege and when i try to go past half throttle it boggs down and it wont go any faster. it goes fine when i ease into it, but when i punch it, it will not do anything. just seems like somethin is plugged up.. but i cant figure out what.
RE: cant go past half throttle
could be any number of things. do you smell gas when you stop and kill the motor? sounds like it idles fine, huh? do you have a check engine light? auto or maual?
no i dont smell any gas.. idles fine.. the check engine light is on, but when i had that checked out, they said everything read fine. could it be the fuel pump?
its manual
hey k, I had that same problem and it may sound stupid but it was my catylytic converter. I "fixed" it and have not had a prob. Also chk engine light went out. Hope this helps!!!!
Matt |
If check engine light is on then everything cannot be checking fine. A trouble code should have been stored that may help point to the problem. Do you remember what code # was stored? Should start with letter P and then have four numerical digits following.
Power loss as you describe could be caused by restricted exhaust as was probably the case with mattstpier. Could also have a fuel pressure problem. Faulty air flow signal, timing belt jumped, etc. Does the engine rev up normally when just sitting at an idle or does it also bogg down then as well? |
the code was P0421.. they said it was just a dummy code?.. when i have it in nuetral and rev it up, it bogs down also, same as when i drive
i'm guessing that the fix for the cat that you speak of involves a broom handle, huh, mattstpier
ok its not the cat converter. getting a fuel pump soon.. if that doesnt work.. then i dont know whats next..
could be a fuel regulator instead of a fuel pump. if you do your own work, i would say that the easiest way to tell is to pinch the fuel return line and see if it acts any different.
| All times are GMT -5. The time now is 08:15 AM. |
