Another no spark
Hi guy's I've got a 1994 protege 1.8 sohc another guy has already changed ,ecm,coil,ignitor.
It started as a stalling cond where you had to pull over and wait.I got it and put plugs ,wires, cap and rotor(tune up) it started and ran fine for a few minutes then stopped now there is no spark at all. it has power to coil and ignitor and is grounded, primary and secondary resistance is in spec, there are no codes. Could it be the pickup? There is no test for this in my crappy manual can it be tested? Thanks |
RE: Another no spark
Here is what I have concerning testing of the distributor hall effect sensor.
[IMG]local://upfiles/1828/EF57CD670EAF417DA560AF4EE9A50EF2.jpg[/IMG] [IMG]local://upfiles/1828/5A41EA3ABF194D8BB4F1810A13FA2859.jpg[/IMG] |
Thanks exactly what I needed.
Yep only getting .56(instead of 5v) of a volt signal? to coil And dist was full of corrosion and crap, Thanks again. tommorow is free parts day at the local scrap any other problem parts I should get?.
I do not know of any other known "problem" parts myself.
[:@] I have the same problem and i did check it like you guys said and it does no go from 0 to 5 Volts so how do i fix this.:(
You would be looking at replacing the distributor.
