99 Mazda Protege door issue
Due to a mechanic friend who tried to help, my driver side door is shot. The local pick and pull does not have a 99 Mazda, but they do have a 2000 Mazda. Are the door parts interchangeable?
You should check an online parts site, but my quick look shows the part numbers are the same from 1999 and 2000. You should make sure the other components, like power windows, door locks, etc. match to make the swap easier.
What happened to your old door? |
Originally Posted by Saudade
(Post 169333)
1 Attachment(s)
Ah. The door lock handles use rods to connect to the lock itself. They are held in place using plastic clips. These clips act as bushings too. When these clips break, they often allow the rods to drop thereby disconnecting the handles from the lock. Sometimes pieces can jam the lock mechanism as well.
Attachment 7842 |
Also, it appears the door panels are the same as well (1999 vs 2000). Same as the door though, check for power vs manual door locks, windows, etc. Color may not match.
