95 protege fuse box?
http://memimage.cardomain.net/member...4_163_full.jpgwhere is it ???
I have no dash lights, the ones on the trunk either the car was in a minor accident and one of the bulbs broke in the side light on the front I'm guessing its just a fuse http://memimage.cardomain.net/member...4_161_full.jpg |
RE: 95 protege fuse box?
Would be willing to bet that the "TAIL" fuse in the underdash fuse box has blown due to the side marker light that was damaged in the accident has created a short to ground. The fuse box is located just to the left of drivers footwell. Fuse box cover should tell you which is the "TAIL" fuse. Check the wiring up in the damaged area and make sure a wire to the front side marker is not grounding out onto the vehicle body if the fuse continues to blow.
