95 P/S belt change help
Hey guys, first post here to the Mazda forums. I own a 95 mitsubishi eclipse rs-t with heavy mods. I know my way around cars, for the most part.
However my brothers 95 protege always squeels on a cold start so I told him I would change his belts for him. My problem is I can't get the P/S pump to swivel. I found the two 14mm bolts that are inside the pulley. Had to unhook the ignition coil and crank it to get in there. Then underneath the pump is a "T" bolt thing. Theres a long bolt and another shorter bolt perpindicular to this one. I removed both of those. Still no swivel. I must be missing something, what is it? While were at it, any complications I might run into trying to get the Alt to swivel? Appreciate the help guys, and yes I did search first. ;) |
