95' mazda protege 1.8L exhaust manifold...?
I have been searching for a new exhaust manifold for the 1.8L DOHC.
I was hoping someone might have some insight as to what a parts are available if any? I can only find manifolds for the 1.5L like the Dorman exhaust manifold "674-247". Does this also fit the 1.8L ? On a side note are there any manifold and catalytic converter kits for this engine? -95' mazda protege 1.8L DOHC 4cyl |
Make sure to check RockAuto.com
Thanks! Its a great site but unfortunately they don't have a manifold.
If its cracked, it is possible to gas weld the crack up. The crack should be drilled at either end to make sure it doesn't continue, then "Veed" to accept the filler material, but it can be done. |
Not a bad idea with the welding. Mazda quoted me over 1000$ for a direct replacement part!
As a result I called the performance store to see if they had pacesetter headers for my car and they do! The part is PSM-70-1166 for around 280$. Does anyone done this upgrade before? Is it worth it? |
