2003 Mazda protege LX diagrams
Are there any online diagrams of the engine block for an 03 Protege? I have some work I would like to do, but I'm not 100% certain where the parts are in the car. I looked in the owner's manual with no success.
I want to look at the throttle body, IAC valve, PCV valve....and a fuel pressure regulator (really not sure where this is). Any help, I'd appreciate it....Thanks |
RE: 2003 Mazda protege LX diagrams
stuff like that is usually not posted online.
they want you to buy books however go pick up a chiltons from a local autoparts store. best book for your car you can buy. and well worth it in the long run! |
Not usually dr4g0n3 but sometimes there are exceptions.;)
[IMG]local://upfiles/1377/074E077BDE1645AF9D908DC4736A9C2A.jpg[/IMG] Fuel pressure regulator has the vacuum line to it. [IMG]local://upfiles/1377/D64BA745AAB04A8FB3BAEBD1AA5C4082.jpg[/IMG] PCV valve [IMG]local://upfiles/1377/B943158E0E894E1187295CCB345FCECD.jpg[/IMG] IAC valve is the black cylinder with gold colored metal on sides. The IAC valve is attached to the Throttle Body. The flexible rubber boot from the air cleaner also attaches to the throttle body. |
wow...thank you so much!
