2003 Mazda Protege - Gas Mileage
My 2003 Mazda Protege gives be about 20mpg for city driving, which I feel is very low. Do I need to get it checked? Can I tweak it myself to improve the mileage?
RE: 2003 Mazda Protege - Gas Mileage
There is heaps you can do.
Change the air filter, spark plugs, oil, oil filter, coolant. All in a general service. get your ignition system checked, check for fuel leaks, or modify your driving habbits. |
also try going to a reputable shop and having your injectors thoroughly cleaned (usually around 50 bucks) That is something that I have had done in the past and noticed a significant difference. Not to mention do all the previous stuff as well (full blown tune up)
what is the milage on your car?
standard or automatic transmission? |
I must admit i was a wee bit dissapointed with the fuel consumption when i bought mine last year thankfully i dont need the Air Con on much in Scotland:)
Marky Ps we pay $6.20 a gallon here now im sure there would be riots in the streets over there if it went abouve $3 |
I have had good success with MPG. I average 30 mpg all around. I am also on my first set of tires which are going on 35K miles. Have you checked tire pressures? I run my PSI at 40 psi with the factory Dunlop tires and this could have a big effect on MPG. Just my 2 cents...hope it helps.
| All times are GMT -5. The time now is 04:02 AM. |
