2002 mazda protege es abs light
hi i have codes 32,41,and45 but i can't seem to find what they mean anywhere. my abs cycles on and off when not supposed to and the abs light isn't on all the time.the transmission also starts going crazy downshifting at 70 mph.i hooked the modis up to the obd 2 and no transmission codes.it also started making a noise besides the abs motor in front end ll happend at the same time.any information is appreciated.
RE: 2002 mazda protege es abs light
Ok,
code 32 is a right front solenoid valve, ABS motor or ABS wheel sensor code 41 and 45 are RF wheel speed sensor codes. Things are pointing to the right front wheel speed sensor. If the ABS is kicking in all of sudden, it could cause the ATX to downshift suddenly. |
thanks alot.another question...i have been able to shift my car with the shift kit that was factory installed because if it's in d it goes crazy today the car took over the shifting out of nowhere and wouldn't let me shiftany idea? my speed o was goin crazy also bouncing all over and then balanced out for a couple miles then did it again for awhile. any info would be great
I think that wheel speed sensor also sends info to the transmission. If the transmission is getting bad spped information, it is going to shift funny.
thanks man and yea it's all in relation with that abs sensor put it in and it drives great no problems .thanks alot
[align=left] [/align] |
http://protege5.ugly.net/#ac
Here is a link to a complete shop manaul for your car. Go to each link and save it to your hard drive. It will come in handy... |
