2000 protege dx engine shorting
I recently bought a protege and the last issue I've noticed so far is that the engine idles rough when I turn the AC on. I just noticed that when I do turn it on, there is a short to the engine.
The boot cover has a crack or has some contamination providing a path for the high voltage spark. Take the coil out and carefully inspect it in that area. If you see any cracks, replace it. Looks like coils are fairly cheap.
Due to the age of the vehicle, it won't be long before the other coil breaks down.
I don't disagree. If it took 2 hours just to get to them, then I would have done both, but changing it out only takes about 10mins so Ill replace it when it breaks down.
Gordinho80
Nov 24, 2013 04:50 PM
sza737
May 20, 2007 11:42 PM
