1st Gen Trans Leak
Okay I have a 91 Protege lx With the 1.8 DOHC with a Manual trans. About a week ago I noticed that the transmission was leaking. I jacked it up and couldn't pin point the leak. I replaced both out put seals to no avail. The fluid is coming from the top of the crosmember under the trans. Ill get pictures tomorrow.
John |
RE: 1st Gen Trans Leak
Most common leaks are shift shaft seal and speedo driven gear o-ring.
i have checked both places. speedo has a new o-ring. shift rail is dry.
Make sure the speedo sleeve is bottomed out. I have seen a ton that got slightly cocked and did not seal. Other than the items i mentioned there are no other seals which leavesa case seam leak which i have never seen happen
thats what mistifys me. im droping the tranny x-member tommorw afternoon. the only thing i can think of is a crack in the housing.
john |
Actually there are a couple switchs and shift rod bolts in the case. Could check those as they have sealing washers on them.
