1999 Mazda Protege 1.8 Headlight Voltage drops?
Old 02-14-2019, 02:01 PM
LEM's Avatar
LEM
LEM is offline
Default 1999 Mazda Protege 1.8 Headlight Voltage drops?
Hello!
  • Vehicle: 1999 Mazda Protege 1.8
  • My right headlight is dim when the high beams are on.
  • The Low beam work OK.
  • I have no issue with the left headlamps.
  • This was also happening with the old bulb which I replaced. (I replaced both the right and the left.)
I am trying to figure what are the correct voltages drop that should be present on each of the 3 connectors on the plug for the headlights. I measured the voltages drop on the left side to compare them to the right side and they seem to be different. The difference is, the voltages drop on the right headlight for the middle connector is 12v compared to the left headlight middle connector that has 0v.
FYI: The plug on the right side had been replaced I don't know when, so I am figuring that maybe the cables were switched. That is why I am verifying the voltage drop.
Low Beam:
  1. For the left side headlight plug, the voltage drop for the top middle connector is 0v, the right connector is 12v and the left connector is .1v
  2. For the right side headlamp plug, the voltage drop for the top middle connector is 12v, the right connector is .1v and the left connector is 0v
Hi Beam:
  1. For the left side headlight plug, the voltage drop for the top middle connector is 0v, the right connector is 12v and the left connector is 0v
  2. For the right side headlamp plug, the voltage drop for the top middle connector is 12v, the right connector is 0v and the left connector is 0v
I have attached a diagram that I made to illustrate the findings.
I have tried to find the diagram for this model and year online but, I have not been successful.
Sincerely and regards,
LEM
Nathan83
02-06-2019 02:38 AM
CTTribe
08-25-2008 09:55 PM
blueag6
12-23-2007 06:07 PM
elso
09-23-2006 12:39 AM
elbert
01-21-2006 07:49 PM
Quick Reply: 1999 Mazda Protege 1.8 Headlight Voltage drops?
