1998 Mazda Protege Trouble code help?
My friends Protege is up for inspection but she has a CEL so it has to be fixed first.
1998 Mazda Protege 1.5 Liter Automatic My AutoXray CodeScout 2500 shows the following 3 codes: P0421 P1195 P0505 Is the any one thing that will set all three or is there more than one problem here? I know the P0421 is any O2 sensor but which one? I think the O2 sensor issue is a problem by itself but can the other 2 be related? Any help much appreciated. |
P0505 is idle air control valve easiest way to test this is to unplug the wiring harness going into the iac if your rpm's change you have a vaccum leak if there is no change replace the iac/ P1195 is an egr valve problem it could be a corroded or broken wire in the harness or as easy as cleaning the egr valve/ P0421 unplug your 02 sensors messure the voltage coming off each harness if they are matching you need a new cat converter i had the same code on my gf's car and the cat converter was no good all 3 of these problems are completly diffrent so each one needs to be looked at hope this helps
