1996 Protege back brake hub
how do I get the back hub of a 1996 Protege off, Take the two Philipshead screws out then what do I do to get the hub off it is stuck tight? vinnie can email too vmdonelan@msn.com Thanks
RE: 1996 Protege back brake hub
Here is a detail pic of the rear drum brakes.
You need to remove the phillips screws, most likely with an impact driver if stuck. After the screws are out and if the drum is stuck, you can use a hammer and tap the edges to break it free. [IMG]local://upfiles/1828/C515A0B645DB46C5940145A2E0C869D3.jpg[/IMG] |
Thanks bkey71it is just what I needed vinnie in S.D.
