02 Protege5 PO455 Help
Replaced cap and still getting code.
P0455 possible causes:
-Purge solenoid valve malfunction -Canister drain cut valve (CDCV) malfunction -Loose, missing or defective fuel filler cap-Charcoal canister malfunction -Catch tank malfunction -Check valve malfunction -Rollover valve malfunction -Cracked fuel tank -Fuel tank component parts poorly installed -EVAP hose damaged or loose -Fuel tank pressure sensor malfunction |
Click on the link below:
Mazda Protege Workshop Manuals In particular check out section 01-16 Emissions. Click on 01-16 and it takes you to the EVAP pdf |
