'02 Protege 5 ABS & Park Brake Light in Dash Is On???
Old Aug 20, 2005 | 01:42 AM
babyhuey's Avatar
Default RE: '02 Protege 5 ABS & Park Brake Light in Dash Is On???
I thought they all were four disc as well but noticed that you were Canada so maybe different there. The part number they gave you is a valid part number thru Mazda but retail is $162.30 and still looks to me from the first grouping of digits of the part # that it may be for a 2 disc system. ( B25D-43 as opposed to GE7C-43 ) There is a newer member that I noticed a few days ago that is a parts man for dealer than may be able to get an answer. I would not be able to until Monday when back to work. I will post him a message and see if he can help with this. Let you know what I find out.
Old Aug 20, 2005 | 03:14 AM
roo's Avatar
roo
Sorry I didn't see this earlier while I was at work. I'd have checked on the correct part number.
If you could PM me with the last eight digits of the VIN, it would tell me EXACTLY what part your vehicle was built with, and I'd be happy to ship to Canada. I also offer a ten percent discount off retail to all members on all stock Mazda parts.
Old Aug 20, 2005 | 03:42 AM
babyhuey's Avatar
Thanks roo for sending reply so quick. Will owe you one.
Old Aug 23, 2005 | 03:29 PM
babyhuey's Avatar
Sorry for being pokey Stan2005 but was very busy yesterday. The part number B25D-43-73XG is for the left FRONT speed sensor and show retail for $162.30. Maybe they looked up the wrong part if they said left rear sensor failure?
Old Aug 26, 2005 | 07:16 PM
MAZDASERVICE's Avatar
It is very uncommon for a front wheel speed sensor to fail
mostly when this occurs it is the left rear speed sensor/abs sensor
Old Jan 13, 2006 | 11:16 PM
derwud's Avatar
have you tried ajusting the e-brake screw thats right beside the lever. Or changing your rear brakes.
there is also an adjustment screw on the back side of the caliper.
Old Jan 13, 2006 | 11:17 PM
derwud's Avatar
Old Oct 22, 2006 | 04:38 PM
ashaus's Avatar
I too have a constant ABS light and brake light. Float, fluid and 60 amp fuse are OK. All brakes pads have minimal wear and the e-brake contact operates correctly. Read the post @ pulling the flashing trouble codes for ABS problems. I had 2 codes, 13 and 47. Could you pass along what I am looking at? Thanks.
Zilch
Feb 26, 2015 08:31 AM
N628PW
Nov 29, 2013 05:55 PM
schlompie
Mar 6, 2012 02:49 PM
kyroguy
Mar 11, 2009 10:39 PM
