water pump squeal..
Old 02-13-2008, 04:46 PM
entropy's Avatar
Default water pump squeal..
i've had this odd squealing/screeching noise that comes and goes. i'm 98% sure it's not the belts or the tensior puller for the p/s. all i have is the power steering and alternator (no a/c). my hunch is that it's the water pump, maybe? the noise comes and goes and increases with the speed of the engine but is unaffected by it. by this i mean reving doesn't necessarily make it disappear. any ideas?
Old 02-21-2008, 11:42 AM
entropy's Avatar
Default RE: water pump squeal..
okay, it's most pronounced in extreme cold especially upon startup. and it really sounds like a supercharger. anyone?..anyone?
Old 02-23-2008, 08:03 AM
It could be your water pump, or the alternator, check to see if it gets louder or more constant when the alternator begins to charge.
Old 02-23-2008, 04:54 PM
entropy's Avatar
thanks for your input but, what exactly do you mean "begins to charge"? isn't the alternator always charging the battery while powering on-board accesories simultaneously?
Old 02-25-2008, 06:05 AM
try spraing some wd-40 on the pulleys for each alt,,,pump....excetra and if it stops when you spry one of them ...that where yourproblem lies
Old 02-25-2008, 09:21 PM
turn on the head lights and listen to the alt. switch to high beem and listen for changes.
Old 02-26-2008, 10:28 AM
cl8ton's Avatar
Check the Ford Ranger Forum. There is a group working on this problem there as well.
Old 02-27-2008, 02:02 PM
I had that problem too. check your alternator belt. mine was chewed all to hell, and it finally broke. a new belt and now theres no squeeling
Old 02-28-2008, 05:13 PM
entropy's Avatar
okay, i sprayed the belts with some wd-40 with now change in noise, tempo or pitch. i did notice though the sound was most prominent on on the drivers side of the engine. this indicates to me it may very well be the water pump. i stethoscoped it with no result. until i replace the pump and that eliminates the noise i'm just going to assume that it's the culprit. i don't plan on r&r'ing it unless it fails.
fyi, adding any electrical load didn't change the noise either. cl8ton, do you have a link to the particular ranger forum troubleshooitng this issue.
Old 02-29-2008, 10:38 AM
cl8ton's Avatar
Hello Entropy
It can be found at:-
www.ford-trucks.com/forums/forum35/
So far they havn't had much luck tracking it down either
Have a Good One!
Quick Reply: water pump squeal..
