Trying to die when in reverse...
Old 02-26-2007, 02:55 AM
Tom73's Avatar
Default Trying to die when in reverse...
I have a 2000Mazda B4000. Recently has started to try to die when put in reverse. Will run very rough when backing out of drive, and will die if go very far in reverse. Any ideas where to start.....?
tom...
Old 02-28-2007, 10:08 PM
Tom73's Avatar
Default RE: Trying to die when in reverse...
Anyone????
Was thinking that there may be some type of regulator that changes some setting when you put the car in reverse. Anyone got any ideas?
tom...
Old 03-02-2007, 06:16 PM
shoulda got a manual?
Old 03-02-2007, 10:09 PM
babyhuey's Avatar
Check and make sure the intake air tube between the air cleaner housing and engine is not torn open. This is the flexible black rubber part. Engine torque twists the drivetrain in a different direction between forward and reverse gears and is maybe opening up a tear only in reverse and allowing unmetered air into the engine.
kongquistador
08-04-2013 05:22 PM
Monty24
10-05-2011 04:28 AM
apbbnbanb_07
12-08-2010 02:48 PM
Bob Hubbard
05-03-2009 12:43 PM
////sean////
10-04-2007 09:44 AM
Quick Reply: Trying to die when in reverse...
