Truck Not Firing
Truck Not Firing
I pulled my engine, to put new gaskets all over it. I put it all back together, and had it running, but the timing was off a little bit. The distrubtor was maxed out turning it wise. So i pulled it out turned it a few notches, and put it back in. and not it it will not fire. The coil is getting fire. Its a brand new coil, and distbutor. new plugs, wires.. please help me out, i depend on this mazda for everyday use. its a 1989 Mazda B2600i 4x4. 2.6 Liter Fuel Injected.
RE: Truck Not Firing
The dowel pin is a dealer item only..... Figures!!!!!1and ahalf weeks till i can get it...LoL About my timing. when i put the cam in.. how do i set the timing back to where it goes so it will run correctly. when i pulled the cam, i had the number 1 piston up to top dead center. What else???? this forum is awsome!
Do you have a GOOD repair manual handy? The instructions should be in the book......
Otherwise....
Here is another cool site that might help:
http://www.mazdatruckin.com
Otherwise....
