Throttle freeplay 1984 B2000
Old 09-29-2006, 09:12 PM
Itsnotme1988's Avatar
Default Throttle freeplay 1984 B2000
Any ideas on how to fix the problem of freeplay in the linkage on a 1984 B2000? The piece that is attached to the firewall, with the linkage coming through has a lot of freeplay. It is causing a good 3-4in of play at the pedal with a grommet filling the gap. I will post a picture when I can next weekend if it is needed.
Any thoughts on how to convert it to a throttle cable?
Would it be easier to do a Weber or Holley conversion?
If that would be easier, what Weber would be recommended?
http://www.webercarbsdirect.com/Carburetors_s/2.htm
http://pa.partsandaccessories.com/pa...uretor&dp=true
Old 10-04-2006, 12:11 PM
Default RE: Throttle freeplay 1984 B2000
bump
Old 10-06-2006, 02:56 AM
go to a wreckin yard and find an87-93 b2200 86 may work but get the pedal cable and bracket off the carb
Old 10-06-2006, 11:52 AM
Sounds simple enough. Is it going to be a straight bolt on? Using the entire carb, or just the bracketry and cable (ie using my stock carb).
Any write-ups available?
Old 10-12-2006, 01:34 AM
Anybody?
Old 10-27-2006, 11:08 AM
bump to top
Old 10-27-2006, 01:23 PM
mazdab2600's Avatar
here's some pics of the pedal assembly and adjusting nuts at the carb
(1)check the pedal arm it might be bend if the adjustment nuts dont help
the pedal linkage pic looks the same as my 91 b2600
Old 10-27-2006, 10:31 PM
ORIGINAL: mazdab2600
The '84 doesn't have this. It has a complex maze of steel bars and plastic cups (best way I can think of to describe it). I have placed new grommets where everything meets, and this made a slight difference. Is there a way to just bolt on a linkage from and cable from a newer carb? Even though the '84 F/MA has the carb on the opposite side as the newer motors?
Itsnotme1988
01-19-2007 02:18 PM
Itsnotme1988
12-01-2006 03:15 AM
Itsnotme1988
11-01-2006 05:31 PM
Pappa T
06-16-2006 05:44 PM
Dog_Father
05-18-2006 02:49 PM
Quick Reply: Throttle freeplay 1984 B2000
