short in system
Old 09-06-2006, 09:49 PM
gatedude1's Avatar
Default short in system
I own a 1988 Mazda.B2200 pickup. After it sits for a day or two the battery goes dead. I put a new battery and new alternator on it and it still goes dead. I put a test light on the negative terminal of the battery and put the other end to the disconnected negative battery clamp. The light went on and stayed on while I disconnected every fuse under the hood as well. I then disconnected the large connection on the back of the alternator and the light went out. Thought the problem was a bad diode in the alternator and replaced the alternator. Ater installing the new alternator I hooked up all the connections and the alternator and it is still doing the same thing. If I pull the large plug from the back the test light goes out the same as it did on the old alternator. Please tell me how do I find the short after pulling every fuse and the light stills stays on. I am at wits end.
Thanks Doug
Old 09-16-2006, 03:07 AM
Kyrasis6's Avatar
Default RE: short in system
Have you checked the ignition switch?
Old 09-16-2006, 01:57 PM
gatedude1's Avatar
No I havent.Tested both wires at the connector on the back of the alternator. the yellow wire is hot with key off and that shouldnt be. Going to have to get a wiring diagram. Does anyone out there have one?
Keith Krejci
07-09-2015 03:17 PM
carid
04-30-2015 08:11 AM
Shawn Element
04-16-2014 01:08 PM
Terri
05-07-2010 05:46 AM
Quick Reply: short in system
