rear end swap b2200??
RE: rear end swap b2200??
you need a differential from either an RX-7 or Miata that has LSD, depending on which car and year you find it from it will require different things to make it fit. Some bolt right in, others require some swapping. I think with all of them you need to lengthen the axel by 1/8"
axle, b2000, b2200, conversion, diff, differ, differential, end, good, interchange, lsd, mazda, positraction, rear, rearend, swap, swop
