rear drum brakes
Old 03-24-2009, 12:52 AM
drbigknuckles's Avatar
Default rear drum brakes
have a b2200 was trying to replace the rear brake shoes with new springs and adjusters after tyring for about half hour i gave up the top spring was so tight i could not get the adjuster in place. i was looking on-line for a web page with help on the replacement maby there is a trick im missing??
Old 03-24-2009, 04:44 AM
hixx's Avatar
Put 1 shoe on first then put the adjuster on with it screwed all the way in. Then put the second shoe on and with a thin bladed screwdriver put the screwdriver in the hook of the spring and the end in the hole of the shoe it goes in and let it ride to the hole in the shoe.
Old 03-25-2009, 10:12 AM
Cusser's Avatar
First, make sure your adjusting hardware on both sides is clean and lubed a little. One side is left hand threaded, note. Then adjust the adjusters "in" all the way. To get springs on (on my VW as well), I insert one end then clamp a vise-grip tight on the straight part of the spring on the other end, and pull/use my weight to get the other end in its hole. That's never failed me yet, and I do have an "official" brake spring tool as well.
Crazy Hussar
10-25-2009 08:05 PM
Doug
12-03-2008 11:23 PM
protege20
06-05-2008 10:21 PM
unknownrsx
03-19-2008 11:33 PM
Lucy02
05-23-2007 06:50 PM
Quick Reply: rear drum brakes
