Mazda Pickup Trucks While Mazda may not be known for their trucks, they have always produced quality reliable trucks for both hauling cargo, or simply crusing.
Quick question regarding anti freeze on a 92 B2200
Old 04-07-2015, 04:06 PM
Default Quick question regarding anti freeze on a 92 B2200
Truck is recently loosing anti freeze. I took it to a mechanic shop. He put on a pressure test and left it over night. He said it is not leaking from the test. Fast forward a week, I have been noticing antifreeze under my truck. It's pooling on the fan and looks like it's splatering around under the hood. My question is would it be my Rad? Or something else leaking? I checked my hoses (upper and lower) theyre fine.
Old 04-07-2015, 07:50 PM
Probably the water pump. They are sneaky like that. A pressure test will always show a radiator leak. It might be time to replace the timing belt since the pump is driven by the t-belt. You can see the radiator and water pump easily then. On the other hand, if the water pump is leaking it generally does not hit the cooling fan since it is under a plastic cover. I think it needs to be retested. There is a small bypass hose on the front of the engine that could do that. Again, retest though.
Old 04-10-2015, 08:45 AM
Cusser's Avatar
I agree with the above answer. A leaky radiator should be readily found by a pressure test. Water pump, being internal, typically will drip behind the pulley.
And yes, there are three small bypass hoses on the passenger side of the engine which maybe have never been replaced.
I'd wash off the engine, get it hot, then turn it off, wait 10 minutes (the coolant can actually get hotter that way. more pressure, then look for a leak. Check the hose clamps, radiator ends, even the cap gasket, radiator cap neck, thermostat housing on right front of cylinder head.
You shouldn't need to do the UV dye/black light type test, you already paid a shop, tell them it's still leaking. Do all leak checking with at least 25% coolant, water evaporates faster and is not greenish.
warrior86
09-21-2013 12:46 PM
dalek
11-07-2012 11:11 AM
gsoltis29
03-04-2012 01:16 PM
mazdawelshman
11-06-2010 12:05 PM
chasman
Mazda Pickup Trucks
11-17-2009 07:36 AM
Quick Reply: Quick question regarding anti freeze on a 92 B2200
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
