Popping Noise over bumps!!!
Old 10-20-2008, 12:47 PM
mazda_08's Avatar
Default Popping Noise over bumps!!!
It's happened for a few months now and I still can't figure out what the problem is. I got up under neath the front end yesterday didn't see anything really bad except a crack in one of the boots but since I'm not good with mechanicals I'm not sure which it was (but I know not the Ball Joint) - it's directly below the BJ (LOL).
Any suggestions?
Oh, sorry the noise is coming from the passenger side front wheel. Like I said only over bumps, not during turns.
Old 10-20-2008, 04:09 PM
cochleardad's Avatar
Default RE: Popping Noise over bumps!!!
by the sounds of things what you are expreriencing is a bad ball joint and depending on the year of your truck and if it has the i beam suspension apposed to the independant front suspenion you probably have two ball joints an upper and lower. and unless you have a pressa machine shop of a mechanic will have to perform this job for you and you should change all four, two left and two right, hope this has given you some insight on your problem.
mazpro00
01-01-2015 10:18 AM
HungryJones
05-14-2013 07:16 AM
ruzeckidw
12-18-2008 04:22 PM
possumfat
09-11-2007 11:04 PM
dbaty
02-12-2007 07:59 PM
Quick Reply: Popping Noise over bumps!!!
