Please help it is appreciated
Old 03-02-2019, 02:04 PM
Scottwooton's Avatar
Default Please help it is appreciated
Could someone tell me where to connect the other end of the vacuum advance hose on a 1992 b2200 standard tranny
2. There is a coolant outlet right behind the thermostat in the same housing where do I connect that to. There is another one right near that one also I need to know where I run those to . I can't find this info anywhere. I would really appreciate the help .
Old 03-03-2019, 09:04 AM
Cusser's Avatar
There are three small coolant bypass hoses on a B2200 engine; I assume you refer to that.
As to vacuum line connection: there are a ton of vacuum ports on B2200 engines, and I'm not familiar with the automatics. Look for a port without a cap, or a tee fitting without a hose.
Can you post really good pictures of both issues above? I think that could help, or join MazdaTrucking.com and post your questions and photos there.
MrZee
03-07-2016 08:31 AM
youknowitsgood
10-16-2013 06:06 PM
ocnats milly s
12-15-2009 09:28 AM
soldier81
01-28-2007 03:36 AM
deflepps
04-17-2006 12:04 PM
Quick Reply: Please help it is appreciated
