Please help it is appreciated
Could someone tell me where to connect the other end of the vacuum advance hose on a 1992 b2200 standard tranny
2. There is a coolant outlet right behind the thermostat in the same housing where do I connect that to. There is another one right near that one also I need to know where I run those to . I can't find this info anywhere. I would really appreciate the help . |
There are three small coolant bypass hoses on a B2200 engine; I assume you refer to that.
As to vacuum line connection: there are a ton of vacuum ports on B2200 engines, and I'm not familiar with the automatics. Look for a port without a cap, or a tee fitting without a hose. Can you post really good pictures of both issues above? I think that could help, or join MazdaTrucking.com and post your questions and photos there. |
