not get hot air
Old 03-11-2007, 07:05 PM
lipo35's Avatar
Default not get hot air
i replace thermostat it stall blow cold air
Old 05-16-2008, 07:03 PM
Default RE: not get hot air
Check you radiator fluid level. That is what is used to heat the heater core and without enough fluid it can't heat the air.
Old 05-22-2008, 08:16 PM
also check the valve that operates the heater it might be stuck
Old 05-23-2008, 12:25 AM
i dont know what type of vehicle you have as you geniously decided not to tell anyone. But I had a probelm before with a fuel injected vehicle that was a 92. either the antifreeze was low or the oil was low. and the fact it would not blow hot air was a programed deterent so you would check on those things... check them out and if not i'd go for the heater core.
chrisindfw
09-15-2011 11:45 AM
kibub
01-13-2010 05:10 AM
welbyobeng
06-13-2008 12:20 AM
IMAGEBEN
05-16-2008 05:48 AM
terribletodd
03-06-2006 08:42 PM
Quick Reply: not get hot air
