no power
no power
94 b3000 has very little power at low rpms, it takes about 50 feet before the truck starts to gain power, then its fine until i shift to the next gear then no power for another 50 feet, the rpms dont come up even with the truck floored until the truck starts moving a little faster. once the power kicks in she climbs hills easily. new fuel pump, filter, maf sensor, someone told me its compression? if its compression wouldnt i have no power all the time? cat is clear no blocks, thanks guys...
no power
um new plugs, wires, cap. tps not sure, no code came up for it but i will check it tomorrow, ive found a few broken vacuum lines and repaired what i found, vulcan motor? to be honest im not sure, its the stock motor on the 94 b3000. thanks for the help, ill check the tps in the morning.
x0054
03-08-2008 09:37 AM
