Need help with weber on 86 b2000
Old 03-21-2007, 11:56 PM
Lowboy86's Avatar
Default Need help with weber on 86 b2000
I have the weber carb and I didn't get the directions on whether I can totally eliminate my whole main harness on the passenger side. I know that the computer has 2 plug in's comming out but idk what to do with the plug in's on the manifold and what not.
[/align]
Old 07-15-2007, 08:18 AM
Kyrasis6's Avatar
Default RE: Need help with weber on 86 b2000
For the ports in the manifold and exhaust find bolts to block them off and make a block off plate for the one on the bottom. The one going into the cat you can just cut off and crimp shut. Most of the stuff on the driver side of the engine compartment can be gutted.
Old 07-16-2007, 04:58 AM
The computer is no longer running anything on my truck. I was told that the EGR valve should still be connected, but I couldn't get my truck to run with it hooked up. The Weber carb basically gets rid of everything that robs these trucks of their 85 or so hp.
Old 07-22-2007, 10:43 AM
What's the expected HP gain from the Weber? Aslo,where would I be able to pick one up?
Old 07-30-2007, 04:48 AM
I'm not sure what the HP gain from installing the Weber Carb is. I bought mine online at a place called Weber Carbs Direct. They are well worth the money!!!
greasemonkey2319
02-15-2009 06:56 PM
greasemonkey2319
01-25-2009 04:11 AM
ktgator127
03-26-2008 10:02 PM
ktgator127
03-25-2008 07:55 PM
abgriffin
10-22-2007 09:13 PM
Quick Reply: Need help with weber on 86 b2000
