Need Help with 90 B2200 driveshaft question
Old 07-02-2018, 02:24 AM
sevanlevan's Avatar
Default Need Help with 90 B2200 driveshaft question
Got a 1990 B2200 pickup.The clutch went out.Dropped the driveshaft and about a gallon of oil came out.Got the clutch installed fine.I figured it was rear-end gear oil but when I checked the rear end axle it was still full.Where did all the oil come from and how do I put it back in?Its a manual 5 speed tranny.Its drivable but wont be for long if I dont replace that oil.The tranny?.
Old 07-02-2018, 03:18 AM
Have you checked the gearbox oil?
Is it 2WD or 4WD?
Old 07-02-2018, 04:02 AM
sevanlevan's Avatar
2 wheel drive.Thanks for the quick reply.I think I found how to solve this problem.Take the speedometer cable out and fill up to the hole with SAE 80w-90 motor oil.
Old 07-02-2018, 07:50 AM
Cusser's Avatar
That's one way to add gear oil to these. I check/add 80w90 gear oil through the fill hole on the side of the transmission, use a little pump that fits on the gear oil bottle.
Might be good time to check or replace differential gear oil too !!!
Old 07-03-2018, 02:54 AM
sevanlevan's Avatar
Default Geaar oil
ouldnt gett it in where the speedometer cable goes in so I just removed the gear shifter and poured it in there..However Ii have a new problem. it doesnt wannt to shiff riight.Ittt willl stiick.in first annd thee only way is to double clutch it..Do I neeed to bleed the slave cylinder?
Old 07-03-2018, 07:18 AM
Cusser's Avatar
That's how most of these trucks ended up with torn rubber inner boots at the shifter base.
Do I need to bleed the slave cylinder?
Yes, I would definitely bleed the clutch hydraulics at the slave cylinder.
Note that on these trucks the clutch hydraulics are not so great/sturdy/reliable over time. In the 24 years I've owned my '88 B2200, I've replaced both clutch master and clutch slave cylinder at least 6 times each. I usually replace as a pair, I've even had the situation where the clutch pedal won't return up on its own. I've had to replace the two flexible clutch lines once each in that time.
I've also gone through several brake master cylinders on this truck.
Old 07-07-2018, 02:44 AM
sevanlevan's Avatar
Default Well then thats the problem.
The brakes work but they go to the floor.And the clutch has to be pushed in and out twice or the shifter sticks.How much to replace all three?.{Brake master and clutch master and slave}.
Old 07-07-2018, 08:12 AM
Cusser's Avatar
Estimate $100 - $150 in parts and brake fluid if you do the work yourself, including the manual adjustment of rear brakes and bleeding of both clutch and brake systems. Labor estimate would be 1.5 to 2.5 flat rate hours, off top of my head.
Old 07-08-2018, 08:38 PM
sevanlevan's Avatar
Default problem solved
Installed brake master,clutch master,clutch slave (and clutch)and its running like new.Thanks for your help.I drive up and down the Hollywood Hills everyday and I was afraid I was gonna end up going over a fridge and into somebodies swimming pool.I might sell this thouigh because I found an RV I can get cheap if I get it now..
Carpenterdave
09-06-2014 06:24 PM
jack05
02-29-2012 03:49 PM
MazdaSTL
12-01-2009 05:23 PM
XXBXDUBBXX
09-21-2007 07:53 PM
Daryl
07-11-2007 12:10 AM
Quick Reply: Need Help with 90 B2200 driveshaft question
