Motor Swap in my 89 Mazda B2200.
Hey I need some help I'm currently in the middle of a motor swao in my truck. I'm putting in a 2.2L fuel injected motor out of a 1990 Mazda 626 and so far have swapped the motor mounts, oil pan, and exhaust manifold. So is there any other things that I will run into besides the clearnace issues with my distributor? Plus, I need some guidance on how to do the fuel system. Any help would be appreciated.
RE: Motor Swap in my 89 Mazda B2200.
The throttle body and intake will hit the firewall as well. You'll have to make an adapter plate to turn the upper part around so they face the front.
For the fuel you'll need to upgrade all your fuel lines for high pressure stuff and get a fuel pump for fuel injection. Ditch the mechanical one and block it off.
