Missing Bolts?
Old 06-16-2019, 01:09 PM
ableon20's Avatar
Default Missing Bolts?
Hi everybody, I have just bought a 1989 B2200 5 speed. There is a pretty big leak coming from the valve cover and what seems to be two missing bolts right in front of the valve cover itself. I'm hoping you guys can help me identify these missing bolts or point me in the right direction.
Old 06-16-2019, 07:12 PM
Cusser's Avatar
See this, about halfway down Mazda B2200 & B2000 Cylinder Head Torque
Old 06-17-2019, 09:54 PM
ableon20's Avatar
ahh I see, so they're rocker bolts. I've been looking for a rocker bolt kit but can't seem to find one. Do you have a part number by chance? Thank you for the help!
Old 06-18-2019, 07:28 AM
Cusser's Avatar
I don't have a part number, thread size, or length for these. I'd check with local Mazda dealer, or on-line dealer parts store, and look at their diagrams, or even call them.
You definitely do NOT want too-long bolts, you could beak something if you tighten-up.
Old 06-19-2019, 09:41 AM
ableon20's Avatar
Shoot, so i called my mazda dealership and they told me they are no longer being made, and that it is a stud setup? Can anyone confirm that?
Old 06-19-2019, 10:48 AM
Cusser's Avatar
The front two rocker arm assembly bolts may no longer be available, true. You can post on MazdaTrucking.com and see if someone there has a pair or knows the size. This is not a stud set up, they are bolts, look at my photo above. Sorry, this is the best photo I have right now; disregard that breather hose just hanging there temporarily.
If that fails, measure the depth of the holes, subtract at least 3mm, that's the length of the bolts to look for. Go to Ace Hardware and buy strong metric bolts of that length with 3mm subtracted), believe the thread will be 8.0mm x 1.25mm (if not try 10mm x 1.5mm). Most 8.0mm x 1.25mm metric bolts for sale will have 13mm socket size instead of the Japanese (JIS) standard and that's OK; some Ace have little drawers of JIS standard hardware though with 12mm heads.
Yes, without those two bolts, I could envision an oil leak or worse.
Old 06-23-2019, 03:48 PM
ableon20's Avatar
I've bought both the M8 and M10 bolts with those thread pitches and no luck. im assuming they're M9?
Old 06-24-2019, 08:28 AM
Cusser's Avatar
Could be 10mm with a different thread pitch, don't know. Or maybe the female threads are buggered and that's why previous owner left the bolt out !!!
SPeeDy3
08-07-2007 03:22 PM
Boscatman
01-12-2007 12:54 AM
eflores
06-08-2006 06:17 AM
Boscatman
06-05-2006 11:39 PM
fourbanger
11-11-2005 08:23 PM
Quick Reply: Missing Bolts?
