lights
RE: lights
it could be the switch, or it could be the bulbs. turn your lights on then high beem, then unplug the headlight and use a 12 volt testerto see if you have 12 volts getting to the bulb, if you are, it's the bulbs, if not, it's probley the switch. hope this helps
RE: lights
If it's the switch itself I'd probably install a momentary switch on the dashboard or the underside of the steering column, as the replacementignition switch wires are quite expensive (but try cleaning it first). The replacement is really the switch part and three separate harnesses cabled together: one for headlights,one for ignition/starter, and one other that I can't remember (maybeturn signals). I do remember when I replaced mine 10 years ago ($103 at the dealer, but in stock) that I should've just repalced the ignition portion, as that would've saved me efforts.
RE: lights
If it's not the switch and the bulbs. Try checking the wires. It might be wiredly wrong. But most probably, in the mazda headlights, bulbs are the first to breakdown than switches.
RE: lights
OK, I re-read. If the low beams work but the high beams both don't, and the sealed beam bulbsthemselves are OK for both filaments, it's probably the dimmer relay, a square box under the dash, driver side. You should be able to hear it click when you try to switch from low to high.
anthonytsi
11-12-2008 04:37 PM
Rooster
12-02-2004 09:37 PM
